Ford Focus 2003 Coolant Leak
My car was started to over heat today, when I looked on the ground I found a small leak coming from under the car. It had no coolant in so I topped it up and found the leak coming from here ( please see pictures )
If anyone has any suggestions I would be greatfull
post-70882-0-81142100-1451486884_thumb.j
post-70882-0-18198200-1451486904_thumb.j
post-70882-0-40481200-1451486920_thumb.j
Thermostat housing leaking more than likely in that area
Would I need to take it to a garage or is that something I could do myself ?
Thank you
what engine is in your car?
1.6 LX
thermostat housing then, known issue, well that what im guessing without actually looking at it, it involves removing alternator belt, alternator, then you can access housing, 2 coolant hoses off, 4 housing bolts.
if your upfor doing that .
Thank you so much. I will order the part and let you know how it went. Thanks again
i would look again to see if it is leaking for sure from under alternator before ordering anything.
