Focus Starting Problem
Hello help is what I need.... I have 2001 Ford Focus ghia x and it cranks over but won't start I have changed the coil pack and spark plugs and still nothing any help would much appreciated thanks
Is there a fuel problem anywhere + have you taken a plug out and ran it on 3 to see if there is a spark
Yes they all spark and fuel getting through. I was driving it all day Saturday and was fine then didn't go out Sunday then went to take kids school Monday and bam it wouldn't start 😡
Have you checked the battery? It might not have enough juice to ping the starter dog out
Yeah I have that on charge all night. Just don't know what else it could be
If the engine is cranking over as the OP states the starter motor pinion must be engaging with the flywheel
What colour are the spark plug tips & are they wet or dry ?
Sliver the colour when there new I think that's the colour but there new ones
Anymore help would be nice
If you have Spark and Fuel and the immobilser isnt having an issue then its most likely a sensor has failed on the engine.
Check for any fault codes and don't just go and change sensors for the fun of it. A sensor you should check are Crankshaft sensors etc.
Read any codes if it has any. I would also say you need to double check you have fuel and spark using a light and enough fuel pressure.
Regards
No it's the fuel pump had computer on it today
