Ford Focus Remap
Hi ive just had a remap done on my 1.6 tdci focus [110]
Ive just taken car out there doesnt seem to be the same
power the turbo doesnt seem to be kicking in
and car wont pull as good as it use to does it take a while
for car to learn whilst driving or should it be an instant change
cheers jason
take straight back,that is totally opposite of what a remap surpose to do
Yeah, should be a notably improvement out of the door, did you have the dpf removed as well?
Cheers mate i thought so
Yes had dpf removed and got dpf and egr delete as well as getting remap
I went out tonight expecting car to be loads more responsive
First thing to noticed is that first gear is largely redundant and it should pull like a train right through 2-3k, 2.8k delivers about 90mph, if you have an elm 327 device you can use for scan to monitor the car, you might expect about 280Nm of peak torque, 36psi MAP. All in all you should notice it right away, pop it in third and accelerate from 20 to as fast as you can, feel any different?. It'll only be about 130 and that's assuming the engine is in good nick, so don't expect to be rolling wheel to wheel with mercs or anything
cheers jason
Which remap is it ?
What are the new figures supposed to be ?
Any decent remap should be instantly noticeable
i dont no what remap it is
i was gonna just get dpf and egr delete but was told
remap would make car more powerful and have better mpg
To be honest i normally look on line before i get anything like this done
but didnt bother this time so didnt realise there was different remaps
All i no is we had to drop car off at the garage the night before so
whoever they got in to do it could check ecu and then they send off some where and get an email back
then yesterday he came back and did the actual remap
  • 3 weeks later...
Hi guys had car back in to garage last week
and had 2 faults low fuel pressure and boost pressure problem
was told could be fuel filter so had it booked in and got new oil and filters
now they saying code is just boost pressure problem
I got the misses to drive down the road while i watched couldnt believe
the amount of black smoke coming out of it any ideas what could cause this
would it be more to do with dpf removal or the remap or something not related at all89
cheers in advance for any help
Jason
Crap remap, probably wrong map for that car. Tell em to sort it before the engine is damaged. The garages problem
Sounds like you've got a major boost leak...  Garage probably broke the boost pipe while removing DPF tbh, either that or didn't tighten the jubilee clips...
Cheers for replies
Ive just been out and checked boost pipe the one that connects to the metal
pipe under the engine cover, the clips were tight and couldnt see damage to pipe
The pipe that goes from the mass airflow sensor wasnt clipped together properly
so was loose but still in place im going to nip out in a bit and see if that makes
any difference
Been out in the car and no difference
Think i was clutching at straws
When dpf was blocked a code came up for that but non of the new codes
for low fuel pressure or turbo pressure was in the memory
So would this mean these codes are definitely a problem from work that has been done
Hi, sorry I'm here to see what happens as I'm in the process of doing this, any updates and is it fixed?
Yes mate managed to get home early on weds so had a good look
around and found a split on boost pipe on drivers side i tried to
tape it up but was a bit tight to get on properly
Car does drive better but still a fair bit of black smoke
Hopefully new pipe will sort it out
