Need Heat
Hi i have a 2002 1.8tddi focus that has a real bad prob with the heater the two pipes going into the matrix are both warm but the heater blows cold after about 1 min of heat and it seems to be a flap or something trying to open in behide the dash.also since the heat stoped the ac wont come on plus the button u press for air cirulation in the car dosent work anyone any ideas other than taking the matrix out
Take the 2 pipes off and flush it through with a hose pipe if it's blocked it will help
There is something like a flap trying to move under the dash behind the gear atick where the matrix is located what would that b had a mechanic flush it before didnt do alot
them flaps are control by steel cables that run for the heater controls at the dashboard take a look under your heater both sides see if they are moving freely. . they should be
