Sat Nav Radio Replacement (2008 Focus Zetec)
I have a Ford Focus Zetec 2008 with the Sat Nav radio upgrade in it and I'm looking to swap it out for the Pioneer SPH-DA120 (but am open to options). Just looking for some tips on the things I may need to get this fitted, I know this is a double DIN aftermarket radio so I'm assuming I will need to buy a new fascia panel as well as a new cage(?). Does anyone know the type/how to find the type of kit that would make the current steering wheel stalk controls compatible with these aftermarket radios? I see Halford's offer a couple but are simply labelled "ford", are they compatible with all/most models or will I have to find a specific version for my car?
Any tips on what to look for here? The current fascia panel I'm looking at is this but I'm going to check to see if the current cage is compatible that houses the Ford one at the moment to see if I can just get the plastic font part instead of the entire cage.
Long shot: The sat nav directions from the current Ford radio come up on the centre of my dashboard (a distance to the next turn, an arrow and a road name) as well as on the screen itself, is there anyway I can get this back with an aftermarket system? (I'm assuming not).
Thank for your help!
Aaron
On 17 January 2016 at 10:37 AM, Stoney871 said:
Perfect! Thank you very much. I ended up getting this fascia kit (so I could get the cage as well) but thanks for the help with the wiring and adapters!
