Mk2.5 Broken Antenna - Can't Unscrew
perhaps I am asking a dumb question, but I can't unscrew my antenna. It has broken and I wanted to unscrew it but I wasn't able to do it only using my hands. So I have used pliers and tried. It goes very very hard and in either way I turn, looks like it's just rotating without unscrewing. What's happening? Do I have to change all (together with antenna roof base)? Thanks.
Kind regards,
Gabrijel
safes way is to replace the whole thing don't uses grips if you slip you will mark your roof
Hi DezWez,
you mean, change all together (antenna and base)? The base can be removed by removing interior dome light?
Also, I looked a little on ebay but can't find any antenna base for 2008 MK2.5 (only for 2000 - 2007). Is it the same?
Gabrijel
yes try main dealer
2007 should be the same
Base and antenna for £21 on Amazon (that is inclusive of delivery)
when i did mine i put just a little bit of grease on the threads :)
Procedure to remove the base is like on some videos for focus 2000. that I found on youtube? Remove dome light (central interior front light) and there unscrew antenna base...
Kind regards,
Gabrijel
Pretty much bud :-)
Carefully pry the light housing out of the headliner. If you want, you can easily unplug the light and put it one side. The base is easily accessed from the big hole you now see lol
Mine was the same (on my MK1), I just covered it in WD40, left it for 20 mins then it unscrewed fine.
Remove the base and try removing the aerial once removed. Saves damaging your roof if you slip.
The usual cause is the screw thread being in too tight and the spring coil that actually forms the base of the aerial stem twists around the thread.
Try a set of vice grips right at the base of the stem where it meets the mount.
