Interior Light Upgrade For Mk2.5 Focus!
Hi all, I've got a mk2.5 focus with the standard 1 bulb interior light in, now I was just wondering about changing it to one with map reading lights, I've seen some on eBay and I'm not sure if it's the correct one for my car or not and just wondered if they just plug straight in or will have to rewire, if anyone knows I'd just like a bit of advice 😊
should plug right in :)
do you know which light fitting it is I've seen two different ones so far...👎
don you have any links to what you are looking at
no none off them will not fit ones a mondeo mk 4
the other only goes to 2007 and i think you have a 2010
just read that the secound one would fit
Thanks I might try one of them, or see if anyone else knows
The second one will definitely fit 100%.
It will be plug'n'play too, I do advise popping out the fuse first though as else you will definitely blow it while fiddling with the wires.
Thanks guys ordered the second link one I posted will post when it is done :)
