Airbag Contact Unit
Hi, I changed my steering wheel today (from a 4 spoke to a 3 spoke), the manual says to tape the airbag contact unit so it doesn't move however while I was removing the steering wheel it moved slightly (about 10mm) before I had chance to tape it, I put it back exactly where it was, but is this movement going to damage anything. Everything works ok (airbag light goes on when turned on then off as it should do).
Thanks for any Info
no that should be fine as long as you move it back and ever thing works as it should
Thanks a lot :smile:
It will only be a problem if it moved one or more complete turns.
