RADIO FAULT>
I have a 2003 Focus which has now developed a radio problem and as I don't have the manuals am at a loss to know what to do.
If I turn on the radio the display shows "phone" and will not change, Sometimes it will show "1 hour" in the display, then again it may come on as normal with all stations available.
What needs to be reset please.?
is there not a red phone button you can press? i think the stereo thinks it is on a call hence the phone message.
If the car is not running then it will allow the stereo to be used for 1 hr to save the battery from draining completely.
sounds like the switch under the power button is faulty. One hour mode, is when the car is ignition off, and you want to listen to the radio.
