MAF problems with 1.4 Fiesta 60 plate Diesel
Hi.
Can someone please help.....
I have a 1.4 Fiesta diesel 60 plate. The engine management light came on a week or so ago and when it was plugged in it showed a MAF problem. I bought a new one from GMF and had it fitted but the problem still showed up. I have then taken one off a working car and fitted it but again the problem shows up??????
The car is going well until you hit any sort of hill and looses power.....?
Is the light still on ?have you tried getting it plugged into a diagnostic checking for error codes
Hi yes it had been on diagnostic machine and it's showing the MAF fault code. It had been switched off after putting the new part on and the light just comes back on....
What code? Andhas the wiring been tested to maf?
I'd check the wiring as suggested by iantt
Get a multi meter check your old one and new
Also check the pipe work to the MAF
For cracks etc
Hi  ok thanks will get them checked out over the weekend! Cross fingers !
