engine malfunction warning
hi I got this engine malfunction warning come up on my dash I got a guy to do a quick check and he got the code p0069 map barometric pressure correlation  permanent  and code 042f0 unknown  can anyone suggest the unknown code and is it just the p0069 map thing I need to get fixed I'm clueless thanks for any help
the p0069 could be the MAP, it could also be the barometric pressure sensor tho, the error is a problem between the two figures, not specifically one or the other.  it could also be electrical or mechanical which is causing the irregular readings on the sensors, the other code is new to me
never heard of the other code either irs not a ford or generic code so ide have the codes te checked on other software
thanks for your help guys
