Sidelights/Headlights/Foglights Circular Switch
Does anyone know if it's easy to replace the little light bulbs that illuminate the Sidelights/Heaglights/Foglights on my mk1.5 2004 Focus? Do you have to remove the whole dashboard, or can you access them just at the actual surround of the circular switch?
Thank you,
Liam.
Hi, I have just fitted a new switch. To remove it you need to remove the tray under the column and then remove the cover around the switch. There are 3 screws holding the switch in. If you want I can take pics tomorrow to show you how to remove and how to take apart the switch.
Mike
Mike
Hi Mike,
Thank you for this info, appreciated. It's ok, I know what you mean.
But, if I do run into problems, I'll give you a shout :biggrin:
Thank you for offering to take pics!
Liam.
Hi Liam,
This is the switch apart for you, if you want help then let me know.
The lights are LED's and will need to be de-soldered and then new one's re-soldered into place. I can do a how to guide if you need one.
Mike
3 hours ago, mac801123 said:
Hi Liam,
to get the cover off you need to have the switch in park mode.
Thank you Mike and John. I shall see how I get on.
Liam.
