Mondeo MK4 Heated / cooled seats retrofit
Sorry my first post is asking for help but HI.
I need some help with retro fitting heated cooled seats into a 2007 Zetec.
I have them fitted and bridged the power from drivers to passenger and both 8 ways work well.Where I'm stuck is The heated cooled side.
I will have both seat plugs with plenty of cable coming from themt of the car the seats came from.i will also have the heated seat switch loom.
Ive seen the various wiring diagrams although most point to the mk3.I wondered if anyone has done this on the mk4 and can provide an easy to follow guide and a wiring diagram for the mk4.
One question is the heated switch loom has various plugs on it,i only know where one goes and that is in the switch.Is there a feed from the rear fusbox in the centre console somewhere to plug that into or is it a matter of running fresh feeds in? I'm really hoping theres a hidden loom somewhere to save that work.
Really appreciated!!
  • 3 months later...
Left hand side of gearstick under the centre trim will be a grey multiplug and a green one if memory serves me correct. You will require the loom to connect to one of these plugs which has the heater switchplug. Discard the rest of the loom as this will be the handbrake and rear 12v aux etc. Heater switch plug has Five wires. 2x live feeds. 1x illumination from side lights. 1x ground and one signal wire to the 20160921_132141.jpgseat heating module. Also need to purchase the heated seat module and loom required if you want oem fittings.
