Turbo pipe
Hi all I have a focus 2010 1.6tdci with a hole in a plastic pipe that connects to the top of the turbo , sorry only pic I have its the top horizontal pipe any idea where I can get a replacement
any ideas why this would happen ?
Hi I have 1.8 tdci 2007 had same issue you will hear a wooshing noise when put foot down n turbo kicks in, it's the air getting out of the hole or split in the pipe just escaping and not getting enough boost.
i got quote for original part but looked on eBay and got a blue silicone one which is better n was cheaper.
if you remove the turbo pipe you will probs see split mine was at back couldn't see it until removed from car easy enough job to do yourself.
Thanks for reply been looking on eBay unable to locate any pipe that would fit have you a link ?
Just to be sure it's the plastic type pipe with like flanges on one end connected to the turbo
Looking at your pic you put on am guessing it's this I have edited pic so you can view pipe I mean.
the 1.6 n 1.8 are different but am guessing if you take off the two jubilee clips one each end this pipe n pull it off you will see a split
No sorry it the one shown not even sure what it's called
Hi not sure what it's called its from egr to turbo pipe sorry late reply looking round eBay came round loads pipes not this though.
Did come across this common pipe splitting n it's near yours not sure if worth check
No it's actually holed on top of pipe in picture I've plugged it initially with a putty type glue but need to find new pipe I'll try ford at sometime tomorrow just trying options to see if anybody else had same problem that could help thx Damien for your input
No worries mate sorry can't help dunno why they can't make the 1.6 n 1.8 same way just bigger turbo would make sense
