Footwell Lights Help!
I changed my footwell lights a while ago but one of them went the other today. Decided to change them today and when I pushed them back into the socket the other bulb went out.
Tried putting the orginal ones back in and they didn't work. Looks like the fuse has gone but can't work out what fuse is for the footwell lights. Any help would be appreciated! Thanks
Does it not run off the same fuse as interior lights?
not sure if I've read your post correctly... regarding the bulb that isn't working try removing then turning the it 180 degrees and replacing as the polarity may be wrong.
Am not 100% but I allways thought footwell n interior was off same fuse, quickest way I would do is look in manual n see what fuse runs lights n check them fuses
