Help
ive got a 59 plate fiesta and just recently the warning on the dash has come on saying my drivers door and drivers passenger doors are open when there not and it is constantly bing bing bing just doesn't stop took it to 2 different auto elecricians they both said it was door latches I got them replaced and it didn't solve problem theres no broken wires in door ive disconnected battery nothing does anyone have any ideas please
Hi, must be a nightmare!
On the Focus, the door ajar switches inside the doors all go into the GEM, which is a major electronic module, that is part of the Passenger Fuse Box (under the glovebox in my car). I am reasonably confident the Fiesta will be the same, or very similar.
Unless you fancy diagnosing the GEM yourself (we can try to help, but it is a complex electronic unit), take it back to the better(?) of the auto-electricians, to check out the GEM. It can be diagnosed & tested via the car main diagnostic socket.
If you have questions, or get any results, please post here. May help others.
Peter.
I agree with peter, gem/ bcm likely to be at fault,
Peter.
Thanks so much will take it back today and let you know how I got on
thank you will let you know later its driving me mad
auto electrician couldn't fit me in today said he could see me tomorrow so will let u know thanks again guys
tell him connector c7 pin 10 green/violet is o/s/f door switch   and connector c7 pin 3 yellow is o/s/r door switch
im assuming from your previous post those are the doors that are causing issues?
c7 is one of the body control module connectors he needs to look at.
How did you get on today with your auto electrician?
hi been back to auto electricians he put machine on it its still coming up door latches took it to another different electrician he saying the same when I told them door latches had been replaced they said it wasn't gem as machine would have shown it up but when latches were replaced  they needed to be programed in ??? does any 1 no if this is the case please
I have had a quick look around, & can find no reference to Programming Door Latches.
If a garage replaced the latches, you should query it with them. They should have the Ford workshop procedure.
From what Ian said (and he is usually accurate), there is just one wire (open/close signal I guess) from the "door open" switches back to the GEM/BCM unit. No need to re-programme that. (Though it could just possibly be a LIN bus connection)
 I do not know whether these latches are simple solenoids or motors with on/off signals, or whether they are smart modules with bus connections. Need a wiring diagram or details of the latches to tell that. Details of car model & trim level might help track down pictures or details of the latch.
If we keep this thread alive, someone else might join in who has either re-programmed the latches or knows they need no programming.
Peter.
