Interior Trim Scratches
I was just wondering if anyone had any tips for buffing/removing scratches on the interior trim? I have some scratches around the gear lever trim (as it popped off whilst driving and clips scratched it when changing gear).
Thanks!
cigarette lighter is an option! lightly heat the scratched area to melt the raised scratched edges and rub flat with your finger.
Ahh that's an interesting suggestion! Got me thinking, I have some stuff called 'polywatch' which is for removing scratches from wristwatch crystals (I collect Swatches). It is minutely abrasive and works by ever so slightly dissolving the plastic of the crystal, then filling in the scratches with the original plastic. Do you think it'd be worth trying that!?
Try to remove a bit of trim and use the stuff on the back of the plastic and see what it does! If it ruins it then don't use it.
Could always buy a gear lever trim from a scrapyard to try out the cigarette lighter & Ploywatch ideas & see the results?
