Upgrading to LED DRL?
I'm sure I've been told before cars that have headlight units with the halogen DRL (h15 bulb) can't be upgraded/simply swapped out for the headlight units with the LED DRL...
I love the look of the LED DRL's. Always wanted them! Just wondering if I heard right? Can they be swapped?
Many thanks. Cookey.
It can be done! I'm sure @GingerFlame was going to have it done, not sure tho.
I think you just need to take it to Ford and get them to program your car to the new lights. Probably helps if you know someone at Ford that could do it for you.
Ah right! Interesting! I do know a lad I went to school with who works there, but unsure what department... Hmmm...  Need a new headlight anyway, so might invest in these 😏
Cheers matey!
The lights themselves are plug and play.
BUT the LED Drls will be in reverse for dimming. Ie, when they should be bright they'll be dim, and when they should be dim they'll be bright. This is usually an MOT failure as they'll be brighter than all the other lights.
Needs to be reprogrammed via IDS :)
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
Ah right, cheers for that mate.
A couple of things...
IDS??
And how much you reckon ford will charge for that reprogramming?
IDS is basically dealership level diagnostics equipment which costs thousands & thousands of pounds
Most Ford dealers won't touch it, some will but only if the "master technician" is willing to do it.
Where abouts are you located? I know a few people
Blimey. I'm really wanting these in too.
I'm in Barnsley, South Yorkshire mate.
Thanks. Cookey.
Looking through online breakers too, trying to get them below other new prices.
Anything then Kieron? Who's going to do yours for you buddy?
The main person I know of is in Brighton.. so quite a drive haha. Although it's a drive I'll be making as I don't really trust any of the other people I know of that are closer
This is the one thing which bugs me on my ZS
Well... Fair enough! Think I'm going to contact TrustFord Barnsley, see what they have to say... Or might nip in after work tomorrow.
I'm down near Brighton, wouldn't mind which garage you're gunna be using for this :smile:
That's good timing! He can do it cheaper on a Saturday ;)
Have you got instagram? as that's probably the easiest way to contact him. I've asked him for a contact number for you
Any pricing you can give me kieron? So i can approach TrustFord Barnsley.
Thanks.
Cookey.
I don't have any prices but speak to Tom as he's speaking to the master tech in question
