Seat scuffed can it be removed?
Can this scuff be removed? Its about 4 inch long the cotton slighty raised on feel... Would putting a iron over it help? Or nothing will do anything dont wanna get a new seat. Its a 16 plate so bit annoying cheers
I don't mean to sound rude or anything but you sure it's a scuff? Because it just looks like a 'I've sat here' crease in the seat :unsure:
It is scuffed its raised and u can see the cotton has lifted close up and feel over finger it was a metal button on back on jeans did it was sharp
think it will be a new seat cover  that sort of damage may well not be covered under warranty as they may say its customer abuse for sitting in it with sharp buttons. although they do replace some seat covers that are damaged under warranty i had my driver seat cover replaced as the plastic trim wore 2 holes in the seat material
http://www.fordownersclub.com/forums/topic/83729-ford-warranty/
A new lower bolster cover can be purchased from ford but be prepared to sit down as they are expensive.
Not that easy to re-fit neither as its so tight.
This guy on ebay has your cover :tongue: So don't fret too much.
http://www.ebay.co.uk/itm/GENUINE-FORD-FIESTA-FIT-LH-RH-FRONT-SEAT-COVER-11-05-2012-2016-/302019094182?hash=item4651bda6a6:g:0x0AAOSwOdNXP2eM
To change the cover disconnect the car battery under the bonnet. Unbolt & disconnect the electrics from under the seat. Unbolt the seat and remove the seat, I found removing the seat the safest way was to lower the rear seats, wind the front seat right back, then with the help of another person remove the seat through the boot, ensuring the rails don't scrape on any plastic trim, get a bed quilt to cover the rear seat for protection.
Take the seat in the house and put the seat upside down on the settee and then work on removing the plastic trim and note how the cover is all held in place.
Remember the seat has airbags so be gentle.
