Injector removal
do anybody know the best way to remove a stuck injector?
i have removed 3, just can't remove the last on. Any help?
Might be safer ways but I'd try cranking the engine over...the compression should pop it out.
Have tried, engine not starting though.
Which engine is it? You can get injector pullers to get them out, I found on a Clio DCi that if you put a spanner around where the 'claw' of the injector mount was and careful turned from side to side it started to loosen - just be careful as some injectors can get damaged if any force side to side (which is why the injector pullers pull the injector perfectly vertically.
