Ford Fiesta won't turn over/start - battery seems fine? (video inside...)
This is a bit of an ongoing problem with my 2007 Mk6 Ford Fiesta (semi-automatic transmission, if that makes any difference...). It's extremely intermittent; the last time I had an issue with it was probably about six months ago, and it's started fine every time between then and now, but every now and again, when I turn the ignition key, instead of turning over the engine just makes this long, pronounced "wheezing"/grinding sound for as long as I turn the key… A mechanic I took it to one side he simply cleaned some of the battery terminals with a wire brush and that seemed to alleviate the issue, but I'm wondering if that was actually a fix or just a temporary thing/coincidence. Lights/wipers/everything works fine and it's a -1yr old battery so I'm assuming it's not that?
This short video will hopefully explain what happens better than my text could:
https://youtu.be/hYDvo1zApEc
Anybody know what that sound is?? Could it be the starter or something?
