FuseBox F19 Pin Wiring/Diagram - Fiesta Mk6
Hi All,
Is anyone able to tell me where f19 cables run to and from? Or provide a wiring diagram. Fiesta Mk6
if its for fiesta as per your profile, then it feeds the daytime running lights relay k5 at fusebox connector c409 so internally fed.
do you mean r5? you dont have a wiring diagram by any chance? is there suppose to be 12v continuously there?
there is no wiring diagram as such, the fuse f19 is permanant live from fusebox main feed, then it internally goes to via orange/blue wire to pin3 for the relay.
Thank you for the help ill look at this tomorrow.
Just to confirm its R5? relay as i cant see k5?
There isnt a k5 relay in place as you can see from this picture. This is a friends fusebox with autolights factory installed.
f19 is wired up without k5 relay. Is there another way this is wired up.
