Fiesta ST-2 2013 - Suspension Set-Up
I am looking for a better suspension set up on my Fiesta ST 2013 - Mountune MR230 package installed with billet quick shift as well.
Currently I've got it lowered onto a set of H&R Sports Springs - around 35mm lowering - and spaced on Eibach Pro Spacers - total 30mm track width widening front and rear.
I am thinking of going over to coil-overs though because the ride is still too jiggly and a large part of that I think is the spring rates and damping set up - the set I'm looking at are BC Racing BR Series Coil-overs - could anyone give me any advice as to the best set-ups they've found?
I appreciate any help and advice that comes through!
I can't help you with your question - sorry, but I do have a couple for you. Your spacers are 15mm each? What wheels/tyres are you running?  How have you found the wider stance has affected turning circle and large bumps mid-corner? Were the springs hard enough to avoid fender rub on rough roads? Thanks.
Yes they are 15mm on each side, front and back. Wheels - Stock ST alloys - Tyres are Michelin Pilot Sport 3 205/40 R17 84W
No affect on turning circle that I've found - no fender rub on rough roads - not noticed any difficult with the large bumps...
All is good here! This is how it sits...
Thanks for the info. Your car looks great. Good luck with the coilover upgrade 👍
Found this may be of some use to you
@winslade6770 That's great thanks!
  • 4 weeks later...
Went for the BC BR-RS Coilover kit in the end - best decision I've made with the car so far I think! Pictures to come soon on my build thread...
Watching!
