NO indicators/outside temp/red frost/hazard/handbrake light
Hi all
Would anyone know how to cure this problem
I have watched a video on YouTube that says the connection on the bottom of the fuse box under the dash can come loose and to make sure its fitting properly
I have tried this and I still have the issue
Can any one advise on this before I go to a auto electrician
many thanks
in advance
Rob
i had this on mine it turned out to be the  outside temp sensor witch was at the front of the raditor
took it out cleaned it and it all went right hope this helps
as you can see the temp gauge is not reading anything
google this// 2007 ford focus outside temperature sensor location
thank you Dez
will take a look
rob
  • 3 years later...
Hi Rob
Have you car been sorted? I have exactly same problem and saw the same you tube you mentioned to check the connectors come loose. I tried but still didn't work but haven't tried the temp sensor yet. Went to the garage and they can't fix this.
Reilly
