Oil Filter Location - Focus mk3 2012 2.0 TDCI 140 Engine
I have found it, since I know the housing to look for from my old focus, but on the 140 it seems to be half buried under the front of the engine.
Any tips on how to swap it out?
Also is the sump and plug in a similar location to the mk2.5?
Very little info about this engine.
think you`ll find you oil filter between the air filter box and the engine if you look down on top of it, just undo the air pipe to see the oil filter houseing better.
sump plug should be in same place, but you may need to remove the bottom engine cover (if fitted)
That's not where I've seen it then...
ill have a look in the morning
https://teon.co/cars/ford-focus-diesel-2-dot-0-tdci/manuals/51b71df6a114603275000065/chapters/interim-service/chapter_parts/oil-filter-change
see if this helps you find it better :rolleyes:
Wrong engine mate. This is the problem I'm having - the 140 doesn't have that big engine cover, just one half the size
they seem rare
it is right behind the oil filler eeeeek :-(
if im wrong im sorry
Jamie
Jamie
Appreciate the help - yep that appears to be it.
Where has teh image come from and what do the arrows represent?  It looks a disaster, but I'm thinking it cannot be as bad as it looks?
Did u find oil filter. I have same engine and just serviced myself.
Hi
Im sorry that iam late to reply
The RED Arrow points to the oil filter which is inside the black done Dome. Its the only image i could find with the oil filter in it
Jamie
