Check coolant level hot or cold?
Hey All,
Just wondering should I check my engine coolant level when its hot or cold? I was just driving around and decided to check the level and saw that its on the "MIN" mark.
Should I top it up or shall I wait until the engine is cool then check the level again?
Cold, and don't undo the cap when engine is hot, the cooling system is pressurised.
Thanks mate - should I fill it to the max level or just in the middle between min and max?
3 hours ago, kingsblue said:
The cooling system is pressurised
...and when the system is pressurised it can give a false reading.
Really? :wink:
Really? :wink:
Yep unfortunately really 🤔. I was always under the impression the closer to the max line the better but since then ive been told conflicting things.
Yes mate. Fill to the max line when it's cold only.
just make sure you have the correct grade of coolant thou for your vehicle.
Thanks mate
