St 250 boost solenoid valve
there some sort of instructions at the bottom of the page you put up :smile:Which way around do the pipes go ?
The valve has each port numbered 1 ,2 and  3
Port 1 = Return line ( this goes back into the turbo intake which faces upwards on the start of the Turbo intake)
Port 3 = Presure feed ( this goes to the line that exits normally from the side of the Turbo intake)
Port 2 = Actuator Feed (this line goes directly to the actuator.)
Please be aware that the unit will not work correctly any other way around and could result in serious overboost problems and subsequenet engine damage if not proprly fitted
.If you are in any doubt whatsoever please print this page and take the Pumaspeed uprated solenoid valve to a professional workshop for installation.
Dez, i did see that but im more after where is this soleniod valve and which line is which :unsure:
Has anyone done this mod can help a lad out :)
If anyone is interested in this mod the valve is located just on the turbo, its a wheel off wheel arch out and you should be able to get to it
