All dash lights are on when I take my key out of the ignition
Hi all got a problem with my 02 ztech fiesta not sure if it stems from driveing through a pot hole the wipers randomly came on  or when previously trying to change fuses when my radio wouldn't work ...when I take the key our all of my dash lights are on if anyone know what I can do to try and fix this ?
You will need to check your fuse boxes for water ingress or loose connectors. Check all your fuses are secure and in the correct spaces (check your manual and check you have fuses in the correct places). Does your engine stay running when your key is removed?
I recall someone had a similar problem with ignition staying on when they put a relay in the wrong way round, causing their headlight permanent feed to be connected to ignition live.
