Changing fog light bulbs in mk3.5
Hi
Does anyone know to change the bulbs in the front fog lights on the standard focus (mk3.5)?
Mark...
Pull the grills off; this allows access to the lights that are held in with 3 screws. Remove the screws, take out the light assembly and remove the bulb by turning it anticlockwise. You will need to disconnect the plug before you can remove the bulb. Hope this helps.
