Key enquiry
Hi all. I have recently purchased my 1st Ford a 2011 Focus. It came with a key I can't find any information on in the manual hope you guys can help.
Thanks.
Definitely nothing original to do with the car.
I'd say it was for a steering wheel or handbrake lock (or something similar).
If you didn't get anything like that with the car then dump it.
Do check that your OBD data port isn't in an aftermarket ptotection case first though.
Pull open the storage tray under your headlight control knob, squeeze the upper rear edges together and hinge the tray right down.
The OBD port should be obvious at the bottom edge of the tray recess.
If you can see it clearly then all is good and that rogue key can be thrown into the back of a junk drawer somewhere.
Could be from a lockable after market fuel cap so if you haven't already filled up then check that too. I have to say though my first thought was also a steering lock or the like.
