Electric window problem mk2.5 titanium
Hi just a quick question we have a mk2.5 titanium the passenger front window and mirror don't work from either switch and the passenger rear only works from the switch on that door and neither of those windows operate when using the global closing/open function on key fob? Would this be caused by the drivers door switch panel or is there some other control unit that may have gone I've checked all fuses but nothing thanks.
have you checked the fuse ?
I would get it hooked up to check for DTC codes that kind of thing will almost always log an error code which just might help pinpoint the source of the problem or at least give you an idea of where to start checking from. I would check the ground point for that wiring circuit also as you may just have an open circuit from a poor ground connection or a broken/damaged wire.
