Child locks not working
Hi, I have a problem with the child locks on my 2009 Mk2.5 focus Zetec. The passenger rear door will not open from the inside no matter what setting the child lock is set to. The drivers side rear door child lock doesn't work at all, you can open it from the inside whatever the switch is set to. The main central locking works fine on all doors. The child lock switch on the drivers side rear door is loose and flops about in the hole and the one on the passengers side doesn't feel much better. Are these items expensive to replace? Are they fairly easy to access once the door panel is off? I don't want to go delving in and then find there is an easy fix!! Cheers
