suspension change
Hi basically i have a normal focus mk3 zetec, i want to put in the suspension from the zetec S. Is it just a simple swap or would mountings etc be different?
Cheers
Dom
all built the same , so id say yes,  yet the car is designed in a certain way, so yes  the suspension will fit , will the car handle differently look on ebay there is a vast choice  of suspension parts
Cheers
Dom
ZetecS is just a zetec with a body kit and lower springs,
You could do better than ZetecS by fitting eibach lowering springs.
Ford can supply them for your focus there's different springs for petrol models and diesel models
They fit the existing shocks by design and improve handling aswell as apperance.
Just make sure you have the laser tracking alignment done around two weeks after lowering to correct the wheel surface contact with the road.
Cheers
Dom
Here's an example for mk3 springs http://fordpartsuk.com/shop/ford_focus_mk2_and_mk3_eibach_spring_kit__f_1367646.htm
That link goes to 'Applicable for Estate Cars Only'
The link is for example purposes; I recommend contacting supplier prior to purchase
