Air con leak
Just been to have my air con topped up at Halfords and the guy said that I have a leak in the system.
Not knowing anything about air con has anyone got any ideas where the leak might be and roughly how much to fix this problem? Is there a common fault on these cars where i should look first?
The best thing with air can is to leave this with the experts get a quote then decide what to do TBH it could be anything from a very small hole to a seal and could be anyware. One thing to look out for is a greenish/yellow stain any where on the system this may indicate where the leak is.
They put a UV dye in when they regass it, then a week later they can see where its leaking with a UV torch
I had leak in air con focus if it's mk2 fords put a pipe just behind the front grill from compressor to condenser The pipe bends quite a bit and they leak not cheap bout 150 quid I think from fords plus fitting and re gas or get pattern part
