Ford Focus Broken valve
Hi all, i have a ford focus 54 plate tdci ghia, Noticed a small valve that has a pipe broken, but don't know what its for or called to order a replacement, can anyone help please
The braided pipe looks like a fuel pipe. But it looks different to my 1.8, I am not familiar with the Mk1 1.8 layout. Maybe if you zoomed out a bit so we could see the location, and where the pipe goes, it would help.
Also I can not see the actual break. If it is in a fuel pipe, then it would almost have to be the return to the tank, as otherwise either fuel would leak out, or air would get in and stop the engine.
The other braided pipe on my car is the brake vacuum hose. A bad leak here would cause very poor braking, with hard brake pedal.
