MK2 Focus 1.8 TDCi EGR Issue -- car stalling
Hello guys I'm new here so I'm sorry if I've posted this in a wrong section.
I have a very annoying (and sometimes even dangerous) issue with my focus.
Randomly my car stalls and bc shows "Engine Systems Failed" message on the screen. After I restart the car it works normally. It almost always happens when decelerating or when moving away from a light or a parking space.
This is the error message it stored in the memory:
===PCM DTC P0489-61===
Code: P0489 - Exhaust Gas Recirculation Control Circuit Low
Additional Fault Symptom:
 - Signal is Above Maximum Threshold
Status:
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Wiring Harness Open Circuit
Short circuit in wiring or component.
Short to Ground
Exhaust Gas Recirculation Valve
Faulty or damaged PCM.
===END PCM DTC P0489-61===
EGR control module was changed recently but the problem reappeared. inlet manifold was also cleaned.
Can anyone point me in the right direction to solve this problem because my focus turned itself off in a roundabout and in the middle of an intersection which could be very dangerous and i have a 1000+ km trip soon.
Thank you in advance
