How to fit new shock absorbers?
Hey guys,
I'm fitting new wishbones and shock absorbers this weekend. I've never fit a shock absorber before though. Anyone have information about doing it? If you've done it can you confirm if i'll need a coil compressor or not or if the coil can transfer over to the new shock absorber
thanks
Is this on the mk2 in your profile?
yes you will need a spring compressor
Yes and have you done it before?
Done many hundreds of springs lol and a good few on mk2 focus
Any tips for the shock absorbers then
Not really any tips specific to the focus that I can think of. Usual stuff though, remove drop link, brake hose, abs sensor wire, pinch bolt - I tend to heat the pinch bolt as they can be very tight! 6 point socket only for that and it's 15mm.
I tend to hammer the knuckle down then unbolt the shock but I have done it in the past by unbolting shock mount and knocking the shock upwards out of the knuckle. A wedge in the back of the knuckle helps too.
I would recommend using a new pinch bolt and nut for the knuckle and a new tennon nut for the top mount to damper fixing
The reality is no one does though lol. Pinch bolt doesn't have a nut either, the Knuckle is threaded.
sorry getting confused with the setup on land rovers but still best to replace bolt anyway as they aren't that expensive
Spring compressors are a necessity, and the only reason I don't attempt any jobs involving them myself!
Went on  a treat today. Yes spring compressors are needed. For some reason I thought they were going to be very expensive but got a good heavy duty one for £15 from local shop. Used a jack to get the new shocks on knuckle though
Which compressor did you buy?
