Pollen filter
I am having some difficulty in removing the pollen filter because the end of the housing sits in a dip in the footwell and will not simply pull out.  According to Mr Haynes, access is improved by removing the glove box; one side screw, two upper screws and two lower screws.  Done that but the glove box will not part company with the car, still fixed tight.  What have I missed?
they may be a little screw at the bottom where the cover sits in the dip if not then just press the 2 plastic panles on the side of the filter cover and pull it towards the glovebox quite hard. no need to take the glovebox out
squease and pull
Done it; thanks
