Mondeo 2011 Android sterio
Hi All,
I'm fitting an Android sterio but have found that the Antenna for the stock one uses 'Fakra' connections, has anyone done anything like this & if so what connector do I use as I think one is for the DAB.
Thanks for any help.
Colin
The original radio uses antenna diversity, i.e., both antennas are for FM. If your aftermarket radio only uses one antenna, you could connect either, and check which gives you better reception.
