Speaker adapters to replace door speakers in a Streetka
Hi All
I have a set of brand new 165mm JVC speakers sat doing nothing that I would like to fit into my wife's Streetka to replace the current stock door speakers.
Can anyone tell me which adapter ring brackets I would need to fit them as I am looking at mk1 ford ka adapters as I assume they are the same speakers in a streetka and a ka but there seems to be some variation in brackets available.
I am pretty sure the standard streetka speakers are 5x7's.
Are the interior door panels the pop off type too on a streetka?
Any help from anyone who has done this job or better still a link to the correct adapters would be greatly appreciated.
i replaced my speakers with OEM again for a few £ as they sound sweet and the OEM head unit is superb
i think when you take the speakers out the hole is bigger but i forget now.
door card pop off (buy some spares as they snap and be careful as some of the mounts are only glued onto the door card)
there is a screw in the door handle
this revels a screw behind
there is a screw under the door storage area
JJ
Thanks JJ I shall give that a try I was wondering how the door cards come off.   I have got some plastic trim removal tools so hopefully I can get it off the door with no damage.
hi mate
if you tilt the seats forward you will find two area's for i believe to fit rear 6 x 9 speakers as an extra, the connectors should also be there. i believe these could easily be adapted to fit after market ones also
  • 8 months later...
On 8/6/2017 at 4:58 PM, marco.da.man said:
hi mate
Oooo found by accident will look into this myself. Thank you!
