Little help needed
Hi everybody as stated in topic title i need little help , basically  ive got 2007 1.6 zetec petrol automatic and started to install auto window rollup by the diagram bellow ,but cant find alarm systems cable as in bottom left corner of diagram , can anybody help please .been through wiring diagrams but cant seem to find it :( thanks in advance
On the Focus MK2/MK2.5 the original (CANbus controlled) alarm system is fully integrated into the GEM module/fuse box. There is no seperate alarm control module. Apart from some sensor input connections and an alarm horn output connection on the GEM module/fuse box there are no other connections for the alarm system.
Does your car have the standard 2-electric window system or the more advanced comfort (4-electric window) system? If your cas has the standard 2-electric window system you should be aware that this system does not have any pinch protection. On this system the window will close even when something (or someone) gets stuck between the window.
Ive got standard 2 electric window version unfortunately but im fine with them closing that way . Just can't  figure out where to find that cable :(
You will not find an alarm system control cable because there simply is no such cable on the Focus MK2/MK2.5. The Alarm system is controled by the GEM module/fuse box. Apart from the sensors and alarm horn all connections of the alarm system are located on the PCB of the GEM module/fuse box.
First you have to know what kind of signal you need. I suspect that you can use the central locking "close" signal as an alternative (only if the car has no autolocking enabled)..
