Focus mk2 dash cam install
Hi , i have a ford focus mk2 2007, i want to install a dash cam but i have some problems. the dash cam comes with connectors that should fit the fuse box red wire ,yellow , ground, audio, but they dont fit focsu mk2 fuse box , so i bought fuse adaptor for it 2 in 1 but i dont know where to put them... should i take fuse from electric windows and put it in the adaptor with the dash cam wire? or wich fuse location should i use? ...... il leave some pics. Thanks.
Fuse 78 is best.
So il take fuse 78 + yellow wire and put them in to piggyback then inert it in to no 78?
Yep, chop that tatty connector off the yellow wire and crimp into the fusetap.
Put 15A fuse into top fuse slot and original fuse from 78 into the bottom.
The correct fusetap orientation in the board would be with the fusetap wire facing towards the front of the car.
Black wire with c shaped end to any body mounted screw or bolt (handy one near to the fusebox is one of the ones holding the fuseboard bracket in place).
Red (acc) wire?, god knows tbh.
