Hids
Got a 65 plate zs with led drls, fitted a standard hid kit i had on my focus but the lights flash then turn off when i start the engine.
Anyone help me get this sorted?
Cheers
You will need a relay then pal. They turn on with the engine off, and then when you start the engine the HIDs go out, is that right?
Yeh mate, that what happens.
Is it one of those canbus cancellers/decoders i need?
Cheers
sounds like you connected the hid ballast to the wrong light feed if you ask me.........
and even if you dont ask me thats what im sticking with anyway  :-)
I tried them the other way and they dont light up, when engine is off they are fine but as soon as i start up they flicker then go off.
Its something to do with having led drls but not sure why really.
Are they 55w I had that problem with the ST so put 35w in and they were fine
Sent from my iPhone
No they are 35w ones had them about 6 years maybe the problem is them being old style ballasts
Phil, does your st have led drls?
I'm sticking with using a relay direct to the battery so that it gets more power, you could try with a resistor but I don't think that will work. It sounds like because the the lights aren't drawing the same current as your Halogen bulbs the CANbus system senses this and stops any power at all getting to the bulbs. A relay would solve that problem by drawing power straight from the battery when the lights were on.
I assume your DRLs are still working?
Just read your comment about the age of the ballasts. With that in mind I'd say maybe it is time to get the newer style ballasts with built in decoders. Tech is changing all the time and they are probably outdated and not compatible with newer CANbus systems.
It did have yes
Make sure you buy from a reputable dealer not some cheap Chinese eBay ones
Sent from my iPhone
Fiestas dont have canbus do they?
They are ebay ballasts but had them about 8 years so been very reliable!
I wasn't aware of that, cheers for the correction [emoji846]
I'd read they don't have Canbus, but got a message saying Canbus error when I tried LED indicator lights
Update guys, got some canbus decoders, just tried one quickly and the light stayed on, will fit them all at weekend and keep you posted.
Sounds promising mate!
Finally got some time to properly fit the kit, engine on, lights on. Canbus decoders worked so looks good. 😉
Didnt realise how yellow the led drls look until now lol.
