Bllew a headlamp fuse and the dash went wonky
Blew a dipped bulb the other day and fuse 143 was toast, changed bulbs and fuse, ran a fault code check and brought back a generic u1900.
Then drove a while later noticed the clock date and temp were all out,
Managed to reset the clock and c°/f° out but the date won't go past 2014 ?
Only other thing I've done this week is had the stereo out could this be it ?
Blowing bulbs can send a spike through the rest of the circuitry, it may just have been that, hence why the fuse blew also.
As for the date - you need to change it to the highest possible (2014), set it, go out of the menu and back into it, you will be able to set it higher.
