Mk6 DAB
I was wondering if anyone with the Sony CD fitted (i.e. late ST and Zetec Blue models, plus those fitted as optional extra) has swapped it for a CD DAB or 6-CD DAB model, which I believe was available on the Kuga/Transit Connect (possibly others)? If so, are there were any potential issues to take into account? I'm assuming it'd be pretty much plug and play, including the steering wheel controls, however two things I was concerned about:
  • Would the Bluetooth/Voice Control system be easily compatible?
  • Is it difficult to fit a DAB aerial to the windscreen?
Cheers!
Do you know if the DAB model, that you are planning on removing, will easily replace the standard cd6000 unit that is installed on the mk6? Sorry to go off topic slightly
Definitely yes, the size of the space is the same - so quite a few different ones will fit in.
Might have to get on ebay and see what i can find. Having said that i am also currently debating getting something a lot newer on finance.
