Fiesta 1.6 tdci engine woes
Ok so I'm having a fair bit of trouble with my engine. It's pretty high mileage (151800) its misfiring and the turbo is also on the way out due to carbonated oil and lack of oil changes by previous owners. It's never been the best running engine but it's got really bad in the last couple days. Because it's such a high mileage engine I'm reluctant to pump money into parts to keep the engine going when it would be cheaper to just replace it. The engine code is DVA6TED4. These engines are notoriously weak and prone to problems, would other 1.6 tdci engines fit or would they be too much hassle with different electronics? Are there newer versions of the engine that don't have the problem with the dfp causing back pressure? Any help is appreciated thanks in advance :)
