Smoke on acceleration
My 2014 focus diesel zetec s smokes on acceleration and smells of fumes only had it 9 weeks worried sick any ideas
just when it's hot or just when it's cold or all of the time. what mileage is it showing?
Would appear when getting warm 64k
Once it's warm does it do it continually?
I was thinking maybe injector seals
Not all the time
Especially noticeable at night with car headlights behind
car drives fine apart from this
So even once warmed up it doesn't always do it?
I'd be very surprised if the injector seals had given up after just 3-4 years, although never say never.  Are there any visible sign of leaks around the injectors/any "chuffing" noises (yes, as in like a steam train?).
To be honest if it's driving well I wouldn't worry too much, but it's probably a sensible move to start looking at possible causes.
Have you got a modified ELM cable?
It idles fine but smells of fumes drives fine but really shouldn't be smoking on acceleration
also I notice a bit of carbon around the turbo
What's an ELM cable
16 hours ago, Chewy72 said:
What's an ELM cable
One of these mate Modified ELM327 cable, it's USB so you need a laptop to plug it into, they also do a wireless one for tablets/phones etc.  Along with certain software it allows you to plug into your car, see/clear error codes, check live data etc, similar to what garages use when they plugin and charge you £50 for the privilege.
Injector seals can make it smell fumey under the bonnet and hence come into the air intake to heater vents inside car.   I can't see that the injector seals would cause smoke out of the exhaust .
as above "Are there any visible sign of leaks around the injectors/any "chuffing" noises (yes, as in like a steam train?)."  (at the base of the injectors where they go into the cylinder head)
Not sure seems abit hesitant when cold and smells
