Clutch Problem 07 1.6
OK so i have an issue with my clutch that has happened a few times now.
i had to do an emergency stop the other day and pushed hard on my clutch and it clicked and stayed fully pushed down. i managed to free wheel down the hill an pull over so that i could get down and grab it and pull it back.
clutch still works fine but its happened again recently and want to know if this normal or something i need to sort.
At 1st I would check clutch slave cylinder.
think i saw this problem before on a post on this site.   the plastic road that goes into master cylinder has a wider part on it to act as a stop when the rod goes in a certain amount. whack the pedal down too hard, the wider part whacks the master cylinder and breaks part of the wider stop off the rod. this means the narrowed stop part of the rod gets jammed in the opening of the master cylinder.  I think that is what was describer before.  I think I suggested maybe putting a small worm drive hose clip/jubillee clip around the rod at the relevant point .
pic shows the wide part on the rod halfway along
812952_volvo_s40,_v50,_ford_focus,_2004-
