DPF Filter
Hi. Ive just had to change the dreaded DPF filter on my focus 1.6 tdci as it had split. The car is in limp mode with error code P242F which is if im correct DPF filter blocked. AA mechanic tried to clear code but it will not clear. Any one else had any issues with this code. Thanks in advance.
You may need to reset the DPF parameters.  Can be done with FORScan but not a standard code reader.
