Focus 1.6 cambelt change & touch up paint.
I've booked my Focus 1.6 (non VCT) in for a cambelt change in the new year. My garage is going to be using the genuine Ford kit, but I just wanted to know whether this has a water pump as well or whether I need to ask for this separately. Also, I'll be filling in a few scratches with a Halfords touch up kit the last owner left in the boot and was just wondering how many coats of primer, paint and lacquer I should use?
The water pump is a seperate part.  A genuine pump, gasket and bolts is around £100.
The touch up pens are not the best tbh primer would only be needed if the scratch has went right down you might get away with just the paint and lacquer and the amount depends on how deep the scratch is so as many coats to get level really and desired amount of lacquer for finish.
